I recently fitted a Leo vince tt exhaust and a 68 jet on my 13 plate aerox now when I ride it it will accelerate fine from a standstill but if I let the throttle off while riding then apply the throttle the power won't be there for a few seconds then it will kick in does anyone know what the problem could be
Aerox problem
did you replace your roller weights.
roll on roll off , you tend to find when you roll off the throttle then roll back on the throttle the variator weights are a little to heavy and the rear pully fails to squeeze in allowing for the ratio gearing to drop to the lower ratio. the variator is still open because of the weights.
you could find lowering your roller weights by a gram and adding a stronger contrast spring will allow that variator to close faster and the contrast spring adding a little extra force to close that rear pully and bringing bike into the lower ratio quicker when your rolling on and off the throttle
| Yamaha aerox 50 javing no joy starting | 25 Feb 2017 |
| Bike broke down at shops | 23 Feb 2017 |
| Gilera runner 50cc sp 2010 EXHAUST | 21 Feb 2017 |
| dont foget to unlock your bike | 21 Feb 2017 |
| Keeping your hands warm | 20 Feb 2017 |
| Ackyuklad | 16 Feb 2017 |
| Kymco Agility 125 - Changing the brakes? | 14 Feb 2017 |
| Help. Key broken in lock... | 12 Feb 2017 |
| Gilera Runner 200cc question | 12 Feb 2017 |
| Yamaha Aerox electrical problem | 12 Feb 2017 |
