Hi! Have a bit of an issue, about a week ago i tried to start my scooter it started fine. But as soon as i cranked the throttle it bogged down and died. I tried to start it again but it struggled to keep running and after playing with the throttle for around 30 seconds it magically started to run fine. So i thought that i might need to clean the carb, but i chose to ignore it for now as the bike ran fine when i drove home.
But two days after that i had the exact same issue, but after playing with the throttle so that the bike would idle semi-okay it felt really under powered. So i chose to clean the carb and replace the fuel filter, did that and for the first 2 minutes of riding the bike again it ran as it should. But after that it felt under powered again, so out of paranoia i cleaned the carb again... Surprise, no change.
So i was wondering what i should do to fix this, i recently replaced the air filter and am now wondering if i put to much oil in it? Not sure if that is a possibility but i really don't have a clue.
Many thanks for any possible help!
