Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
Peugeot speedfight II -08 variator
Discussion in Scooter Tuning started by MotoMoto, 5 May 2020
MotoMoto#1
Hi there.
What is a correct way to disable restriction?
1. Number three and four are useless, i will leave them on the table?
2. Number three is useless, assembly everything else, just leave number three on the table?
3. Install small spacers under restriction and assemble all parts including number four?
4. Something else?
Really hard to find good information, if somebody could point the right way to do this, i would highly appreciate it =).
Thanks!
scubabiker#2
If I recall 3 and 4 are the restriction. For sure 3.
PEUGEOT TKR 50/70cc seizure15 replies19 May 2020
Which 70 cc kit should I choose ?18 replies14 May 2020
Exhaust for MHR TEAM15 replies11 May 2020
Upgrade Rollers and belt2 replies11 May 2020
yamaha aerox (50) tuning, pls help5 replies7 May 2020
Cylinder cover/air shroud for Typhoon3 replies8 Apr 2020
Big bore oil/fuel ratio with injector question2 replies23 Mar 2020
Help with oil/fuel ratio when running injection & pre mix with 70cc big bore kit.0 replies23 Mar 2020
Help with set up for Top Performance Due Plus7 replies14 Mar 2020
Sr Factory injection to carb, rpm and temp sensor problem1 replies11 Mar 2020
