Perhaps someone has the experience. Friend of mine bought a Factory which had carb conversion done, but since the stock version has 2 pin temp sensor which goes to Ecu and piaggio engine has 1 pin connector going directly to temp gauge, any info how to get it them two running? same thing with rpm gauge. Any info? Thanks in advance!
The only realistic way you can get them both running is if you change the stock versions 2 pin temp sensor for the piaggios 1 pin connector and vice versa. Not an easy task unless your are a mechanic who specialises in electrics. Might be easier to change the piaggios 1 pin connector for the stocks 2 pin sensor initially and see where that takes you. Should be fairly straight forward although I haven't done it personally. Probably electrocute myself. Best to leave it to a specialist. What was the reason for the carb conversion anyway.
