Scooter Shack Scooter Forum
Suzuki ay50 overheating
Discussion in General Scooter Discussion started by Bryan, 21 May 2017
gilburton#41
Ok seems you have found a problem.
Can I just go back a bit and ask did you check the thermostat as Merlin suggested?
I have read and re read the posts so far and can't see any indication you have checked or replaced it?
Only asking as replacing heads/barrels won't help if the thermostat is faulty.
If you still have problems after replacing the reeds check the auto choke if it still has one.
Bryan#42
Yeah bought a whole new water pump which came with a new thermostat
gilburton#43
Ok but just as a matter of interest did you check the old thermostat?
That may have been your problem in the first place.
Bryan#44
Yeah when I took the old thermostat out it was in 2 bits which may have been the problem from the start. So now it has new thermostat,water pump,barrel,piston,head and gasket and the reeds which will come Wednesday
gilburton#45
Shame you had to spend extra on all the bits for the sake of a thermostat.
Should be excellent now though.
If it still doesn't run properly and before spending more money as I said check the auto choke.
Bryan#46
Just a bit of an update put a new set of reeds in and after replacing the head bike seems to be sorted running better than it has since he got it thanks for all the help
Tamiyacowboy#47
awesome news Bryan make sure he takes it a little easy on that new top end no flat out hooning just let it feel an full open throttle every so often to help seat those rings and cylinder walls . i would also say you derseve a quick blast round the block on it to all the hard work you put into the rebuild and setup , mechs should always get to run the machine after they tinkered it ;)
Bryan#48
Yeah I had a blast on it. Still got plenty to do just started a restoration on a suzuki gp125
long distance19 replies20 Jun 2017
Honda Dylan 125 odometer issue1 replies18 Jun 2017
Returning a faulty vehicle2 replies15 Jun 2017
How to choose quiet helmet? And what are nice features to pay for?7 replies15 Jun 2017
Scooter making unusual noises2 replies9 Jun 2017
about stock piaggio crankshaft capabilities0 replies8 Jun 2017
HELP carburetor repair kit! SOLVED54 replies3 Jun 2017
Top box lost key!5 replies3 Jun 2017
Peugeot Zenith Shock!1 replies2 Jun 2017
Bad oil pump GY6?9 replies31 May 2017
