Scooter Shack Scooter Forum
Need help aprilia sr 125 2t spluttering when holding throttle
Discussion in General Scooter Discussion started by T33omm, 18 Feb 2019
T33omm#1
Hi guys new to the forum, I have a Sr 125 2t and acceleration is perfect and open throttle is perfect top end is perfect, but say I hold it at 40mph,50mph or 60mph it’s starts spluttering slowly pull the throttle more it’s fine balance off and hold it at a steady speed it starts spluttering again any ideas.
Cheers tom
T33omm#2
Cheers tom
Forgot to mention it’s got a stupid cheap looking cone air filter thing and don’t know if it’s been jetted for this
Stevep#3
Thats a wierd one.......
If acceleration and top end is fine I would rule out the air filter, that would affect the entire range.
Maybe the air/fuel mix screw needs playing with or maybe the slide needle could do with raising one notch on the circlip (put the clip on the next slot down the pin).
T33omm#4
I just took my carb off and had a look at the main jet and it’s a 100 surely that’s way to big for a standard bike
Stevep#5
Not really, as an example, the vx125 has a 108 main jet as standard.
T33omm#6
I’ve jus
so hopefully it’s the standard jet and the last owner just put a filter on without jetting it
T33omm#7
Can’t get my head around it put standard air box on won’t go past 30mph and bogging really bad, so thought take air filter out see if the filter is causeing it didn’t make a difference tried it with the air box case open still the same took the air box off completely and was running fine up to 70mph no problem so why is it like that with the air box on also this air box is off another bike off eBay I’ve never owned this bike with a standard air box on it it’s always had a come filter on it
Stevep#8
That's because the airbox is causing a restriction.
You might well find that the cause is actually the cone air filter itself.
Had it a few times on a Neos I did some years ago. The K&N type filter looked good but was actually blocked, changed the filter, away it went again.
If the bike is running fine with no filter on, as in you can hold it steady at 50mph without problems where you couldn't before, then that points to the filter.
scubabiker#9
Swap to a sponge filter. The metal bit at the end of the filter is upsetting the air pulses within the carb
T33omm#10
It runs exactly the same with the cone filter on or off stills has the splutter when holding at a speed I was trying to find the standard size main jet but can’t find any info so I had a look at a gilera sp 125 2t because they both rolling nut engines and they run a 86 main jet so my guess it’s way over jetted and it’s running rich
MARSH#11
The std 125 typhoon on a mikuni carb uses a 82.5 main, and yes the runner 125 has a 86 main with std airboxes, a good place to start plus needle second from top !
T33omm#12
![/QUOTE thank you guys for the replies so my main jet is way to big for the standard air box and when I get it all running sweet with the standard air box will it be any faster as I’ve read that a filter on a standard engine looses power and speed
ViN0...drippy t0 tRipPy1 replies9 Mar 2019
Anyone here done the m365 battery mod? How is it?1 replies8 Mar 2019
Hi ppl please can anyone help. Yamaha aerox1 replies5 Mar 2019
Piaggio Zip 2T 2015 transmission problem1 replies26 Feb 2019
Derbi Senda 50 full derestriction24 replies22 Feb 2019
Di Blasi R7 Help5 replies19 Feb 2019
SH 125i 2018 Question5 replies17 Feb 2019
help needed please....5 replies15 Feb 2019
Gilera VX noiser than usual.3 replies13 Feb 2019
Gilera runner 172 gesrs advice anyone got experience7 replies10 Feb 2019
