Scooter Shack Scooter Forum
ForumsMain Scooter TopicsScooter Projects
yamaha rxs 100cc cafe racer project
Discussion in Scooter Projects started by lee mason, 18 Apr 2013
lee mason#41
got my dads mate to take it out today and we followed him in the car he had it upto 75mph and said it still had a bit more to give but he said it didnt seem to run quite right he thinks its either not getting enough air. also he thinks the cluth needs looking at as it dosnt bit till the lever is nearly all the way out so im going to book it in for a service and check over soon as i assuming it will need a new clutch as we had a play with the asjuster on the bars and it made no difference
Mark Emerson Trentham#42
Make sure the clutch is adjusted for you not for dad's mate (different riding style/experience 'an all that),keep
it bog specified then adjust to suit you.
'an speedos on older strokers can be a little flexible on true speeds,take that into account when otr on bigger
mph roads as a 5-8mph different to a copper excercising? fairness 'an you getting a ticket,esp. where they set
up zones to trap people who are.......motivating. :D
lee mason#43
yh the clutch is a bit dodgey as i took it for a quik blast up the road and you cant change gear fast as it dosnt bite for ages
Mark Emerson Trentham#44
Springs, popp ed in my head just now.
lee mason#45
tightened up the chain today and more will be happening as soon as im not skint
Mark Emerson Trentham#46
That is so a bit to keep in the 'travel tool kit' + splitter.
lee mason#47
so bad news on it really went to start it today and i ran for a few seconds and cut out done a few checks and it got no spark. any suggestions on what could be wrong?
Mark Emerson Trentham#48
Not taking the 'p mate (done this myself) but is it switched on/do you have a stop switch as well?,
Run you off a checklist (bearing in mind it's age/components-ign system),:-
Check cap (inner resistor o.k./plug "fit";)
H.T.lead (cheap to replace)
Check all your wiring secure/connected / proper,may have a short.
Ignition coil could be mullered!
Test your c.d.i.
Not running p/mix ?,plug-whiskered??
fuse?,
You'll undoubtably encounter ign.issues if used
on too many short trips..always best too give it a
good long blast on occasion in ratio to short.mark.
lee mason#49
wirering checked
ht and plug checked
fuse is fine
coil or cdi are my thoughts how do i check theese
and yes it was turned on that was the first thing i done as i forget to all the time
Test your c.d.i.
fuse?,
Mark Emerson Trentham#50
wirering checked
ht and plug checked
fuse is fine
You'll need multimetre (to check resistance) and works manual for parts operating specs.
lee mason#51
ok ive got a multimeter and do you mean a manual for the bike ?
Mark Emerson Trentham#52
Oh,and get the works manual 1st as some test equipment needs to be specific.
Mark Emerson Trentham#53
Yes rxs100.manual!
lee mason#54
Yes rxs100.manual!
ok cheera
Jack James Coulson#55
you never use a multi meter to check if a cdi is working. the low amps/current that a multi meter lets out can fry the unit.
lee mason#56
oh think ill just take it to the bike mechanic up the road then
Jack James Coulson#57
just ask them to find the fault, alot of the times they will try find the fault for free.. and tell you what it is.. if so we hey just fix it youself haha
Cockers#58
If I'm correct it would be an oscilloscope for that job?
Jack James Coulson#59
yeh mate
Cockers#60
woo woo
More threads in Scooter Projects
The 4t 125 Sleeper Zip43 replies19 Jan 2014
Cheap scooter for project0 replies19 Jan 2014
Blue - White Aerox by #Adas76 > UK <5 replies18 Jan 2014
Need help with my Typhoon4 replies14 Jan 2014
Ovetto - with a difference ....15 replies13 Jan 2014
Nrg 50 liquid cooled x redge project12 replies6 Jan 2014
Gilera ice0 replies5 Jan 2014
SR 125/172 Project28 replies4 Jan 2014
sr50/705 replies4 Jan 2014
piaggio zip 50 converting to a typoon 125 engine5 replies4 Jan 2014
