Scooter Shack Scooter Forum
typhoon 125r oil change troubles
Discussion in General Scooter Discussion started by 125xrowner, 8 Aug 2017
125xrowner#1
i as you probably see from my name am the owner of a 125xr that i just got out of the garage after 17 years of sitting i want to do an oil change but cannot locate the oil drain plug ...help
MARSH#2
It's a 2 stroke, there is no oil to change, only the gearbox but that will be ok. You could possibly drain the 2t oil tank but that's it.
Tamiyacowboy#3
+1 on this
being two stroke it does not have an oil drain plug , it takes oil from an oil res usually hidden under the seat area and feeds this down to a oil pump unit that delivers a metered does as the crank spins.
what is said above goes, drain the oil res tank and flush it with a tiny bit of petrol , leave it to air out with the cap off. replace the old oil feed tubing thats gonna be gunked up with old oil thats been sitting a long time, then you need to flush the oil pump unit and bleed it when you add the new oil to the oil res tank. from there on its just a case of checking that oil res tank every few days and topping it up with a good branded name two stroke mixing oil .
gearbox oil could be ok but if your doing the main twostroke oil res may as well give the gearbox new fresh gearbox oil to it will be like a mini service for the scoot
125xrowner#4
+1 on this
thanks I'm new to scooters literally bought it used it once then forgot it in garage for 17 years thank you for advice
MARSH#5
Being such an old scooter with parts discontinued you'd be better off selling it to me !!;)
Peugeot Speedfight 3 125cc squeal0 replies15 Aug 2017
Aerox. Ran out of fuel Now bogs1 replies15 Aug 2017
Engine No.3 replies15 Aug 2017
Gilera Runner 2011 50 with 70s won't start2 replies11 Aug 2017
firing problem maybe help1 replies10 Aug 2017
50cc scooter big bore kit.10 replies6 Aug 2017
Piaggio typhoon 125 2T views on MOT failure7 replies6 Aug 2017
Looking for riding group! (Darlington, North East, UK)0 replies3 Aug 2017
70cc Yamaha Jog LC , Jet problem1 replies3 Aug 2017
Gilera Runner 200 4 stroke ID and Imobiliser info1 replies2 Aug 2017
