Scooter Shack Scooter Forum
How is the 2015 aerox restricted
Discussion in General Scooter Discussion started by Ow3n321, 5 Mar 2017
Ow3n321#1
I'm just wondering how the 2015 aerox is restricted
Tamiyacowboy#2
Exhaust is gonna be a pain so its best to replace with a sports exhaust that removes one of the restrictions.
next is the variator, its possible it will have a restrictor ring on the variator sliding boss to stop the variator plates closing fully, removing this allows the plates to close together and raises top speed.
with a new pipe you will HAVE TO upjet the carb so you get more fuel in , if you dont do this you run the risk of damaging the engine and NOT releasing the full power the new exhaust will give.
DO NOT put a new open airfilter on, keep the factory airbox installed it does the job just fine and does not need replacing.
Roller weights will need to come down a gram or two depending on whats installed from factory to.
im sure the other members will have other tips/ tricks that can be used to gain a little more kapow from your aerox.
Noob seeking advice comments help for new scooter purchase etc60 replies12 Mar 2017
just found this out0 replies11 Mar 2017
advice needed1 replies9 Mar 2017
PIAGGIO NRG POWER 49cc help0 replies8 Mar 2017
Question about selling ET423 replies8 Mar 2017
Yamaha aerox kick start1 replies6 Mar 2017
Yamaha aerox 100 spark issue PLEASE HELP!3 replies5 Mar 2017
Question about CBT10 replies2 Mar 2017
Honda Melody??13 replies2 Mar 2017
Sym model4 replies27 Feb 2017
