The indicators dont work. The engine does not turn off when the key is turned and pulled out. Help please!
Problems with AJS Digita 51
possibly the ignition switch has come unplugger or is shorting out?
Im not sure, and if how would i fix that please?
im not sure what your skill set is, so i will start basic, sorry if its a bit slow. but the ign switch is the key switch, im not familair with your specific bike, but you need to get to the back of it and follow the wires, there should be a sort of plug thing, unplug that and see if your bike starts on the kickstart. if it does, and the problem is the same, then its your ignition switch at fault.
hope that helps
hope that helps
Ok thanks
| Dna 50 problem | 31 Mar 2016 |
| the guessing game... | 31 Mar 2016 |
| Need help finding the right jet for piaggio zip | 31 Mar 2016 |
| W5 10w40 engine oil from lidl | 30 Mar 2016 |
| TOP TIPS! | 27 Mar 2016 |
| Kick-starting with the bike running. | 23 Mar 2016 |
| YAMAHA JOG WHEELS ON A YAMAHA NEOS HELP | 23 Mar 2016 |
| .... | 17 Mar 2016 |
| Today seventh march | 10 Mar 2016 |
| First ride this year | 6 Mar 2016 |
