Scooter Shack Scooter Forum
max power just 60
Discussion in General Scooter Discussion started by i3ence, 8 Jul 2017
i3ence#1
Hello, Im new here :)
I have derbi senda sm 49cc 2007 and i've got problem with it...
The problem is that my Senda go only 60 Km/h
i have blocking things (tell me how its called,thing that blocks moto to 60 km/h cuz my english is poor :()
and how i should remove that blocking thing ??
Tamiyacowboy#2
Hello I3ence
blocking thingy hehehe , you mean your senda is restricted and you would like to know how to de-restrict it.
a couple places you need to look into, first is lifting the rpm restriction on the cdi , Anthea do a unlimited CDI , that will allow the bike to rev a lot higher .
Exhaust, your stock exhaust is somewhat strangling the power the engine makes , changing this to a unrestricted exhaust will unleash even more power, BUT if you do this you MUST also have your carb upjetted to allow more fuel into the engine. more fuel = a bigger bang = more power = more speed.
once the three bits above are done , exhaust -cdi- jetting , you can tinker with your gearing ratio,
your engine will have a front and rear sprocket, a bigger front sprocket on the engine and a smaller rear sprocket on the rear wheel will extend your gear ratio overal. i would say no more that two teeth extra on the front sprocket should do you fine any more will put a lot more strain onto the engine and you dont want that to much.
Welcome to the scooter shack and your english is fine :)
i3ence#3
hehe thanks alot :)
scubabiker#4
What year model is it?
And what size is your rear sprocket?
Tamiyacowboy#5
its a 2007 scuba
i3ence#6
y
its a 2007 scuba
yes
Tamiyacowboy#7
gonna hedge its a stock 53 on rear, thats what they used to come fitted with as standard 53t rear and i think it was a 14t front
I3ence would need to count the teeth on the front sprocket im gonna say its either a 14t or a 15 tooth.
i also know derbi did sell a race front sprocket in a 16t form factor.
if he is running a 14 tooth front sprocket he could gain a couple extra mph moving to a 15t front sprocket, but i think a 16 tooth is just to much for the motor to pull , you would tend to see a 16 front and a say 43 rear used if you have a 70cc kit fitted as your producing a good amount of horsepower to pull that final ratio
scubabiker#8
i remember some models had a sort of restriction with the rear sprocket, the gearing makes it totally stupid to ride, massive rear and tiny front sprocket, if you go down the rear by about 3/4 you should see better power.
the exhaust is the main restricter on sendas, either crimp out the empty chamber bit, or buy a tuning one.
Looking for riding group! (Darlington, North East, UK)0 replies3 Aug 2017
70cc Yamaha Jog LC , Jet problem1 replies3 Aug 2017
Gilera Runner 200 4 stroke ID and Imobiliser info1 replies2 Aug 2017
Ajs firefox5 replies28 Jul 2017
Yamaha aerox problem.. Help2 replies26 Jul 2017
Suzuki ay50 no spark3 replies17 Jul 2017
Breaking Baotian bt50-qt11 Most parts avadible0 replies17 Jul 2017
yamaha Slider performance8 replies14 Jul 2017
HELP NEEDED Peugeot speedfight 50cc help 200020 replies13 Jul 2017
Piaggio zip vs gilera runner0 replies12 Jul 2017
