Scooter Shack Scooter Forum
The most irritating part,you've ever lost....
Discussion in General Scooter Discussion started by Mark Emerson Trentham, 9 May 2014
hairyjim#21
how does an engine fall out once, let alone several times!!!!!
it slotted in to tangs that you then had to tighten like the hulk..1954 design.i was young,i didn't care.if i put my feet on the pedals it made it worse.should have welded a washer on but.....COULDN'T BE ARSED...2 speed hand change.tank ,part of the frame .first bike(legal)
Mark Emerson Trentham#22
The bit you find 2 years later,after an intensive spring clean......
can't remember exactly what it is,but have a burning sense of deja vue',
and only realise what it was,after you've thrown it out or lost again.:|.
gooseman#23
Lost the retainer clip & side plate off the chain master link on my KAW 1000..
Luckily I realized something was wrong before the chain came flying off...chain was snatching...stopped to look at it & saw the problem...it was close to disconnecting..pushed it back together
Happy end :D was able to ride a few miles back home & found the chain was just touching in one area, enough to dislodge the clip. Put on a new master link & sealed the clip with silicone to keep it in place
Rockin'EZ#24
Bolts, lock washers and exhaust seal from the manifold on the way to work.
Zooming along fine, then BLATTTTTTTTT! BLATTTTTTTTT! BLATTTTTTTTT!
Cheap fix, but pain in the butt reason to tighten everything often.
Which Scooter the Best4 replies22 May 2014
Nice find0 replies20 May 2014
Your security52 replies20 May 2014
Ever wonder why others drive up your a**e on the road6 replies19 May 2014
YUASA BATTERY & UPGRADES FOR ALL BIKES2 replies17 May 2014
identification needed asap7 replies17 May 2014
scooters exhaust downpipe issue4 replies16 May 2014
What do you wear on your noggin while riding?78 replies14 May 2014
Still an issue!12 replies12 May 2014
fast vespa5 replies12 May 2014
