Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
RICH main jet 94-98 ??????? (wont be a w**ker this time)
Discussion in Scooter Tuning started by dragster, 1 Jun 2011
dragster#1
right scooter specs
dragster 50
-pm tuning 70's
-athena crank
-21mm delorto carb
-yasuni c16
-mallossi multivar
-pm tuning clutch hard springs
-mallossi hard contra springs
-4g rollers
-kevlar belt
right its got a 92 main jet in. if i turn the mixture screw all the way in and drop the clip on the needle to the bottom notch its still abit rich, but when i put it up one notch on the needle and screw the mixture screw out 1 and a half turns it miss fires and runs lean is it normal to have a 94-98 main jet in because i know people who run bikes with leaner jets or is it more than simple carb tuning?
tErr0#2
You were told that you jet was too large and you haven't bothered fitting a smaller one?
dragster#3
yeah well your wrong do you know anything about carbs or did you not bother reading what i put? on a 92 main it will run too lean if i put the needle on the second notch. ive just googled it and ended up back at this site with someone saying there using a 105 main. so im pretty sure im right getting 94-98 jets and its deffinatly just getting the carb set up.
take a look....
http://www.scootershack.co.uk/the-workshop/what-size-jets-to-use-for-a-21mm-carb-on-a-70cc-alloy-bore-t2277.html
northrider#4
in that same post if you look lower down capri dave said:
capri dave said:
yeah thats right, people expect you to suggest a jet or exact set-up
for their bike...and it's never that easy..
it's trial and error...no 2 engines are exactly the same...theres half a dozen
reasons why 2 seemingly identical engines may require different roller choice
or jetting size ;)
tErr0#5
Firstly bye. Secondly you obviously have no idea and have no idea how to read either. http://www.scootershack.co.uk/carbguide.html The needle position and main jet size are at different throttle positions. Changing the needle height wont effect full throttle.
I'll leave this here for future reference however.
Aerox Problems8 replies7 Jun 2011
TNT RACE CARB JETS2 replies7 Jun 2011
Can anyone help not sure whether this carb will fit?????2 replies6 Jun 2011
aerox slow on accelation7 replies6 Jun 2011
gilera runner 2006 -> new model tuning advices4 replies2 Jun 2011
Squish setting Doppler S7R0 replies1 Jun 2011
what shall i do?3 replies30 May 2011
Speedfight 50cc Air Cooled 03 Problems8 replies30 May 2011
Malossi 70 kit help1 replies28 May 2011
TT vs 3608 replies25 May 2011
