Got my speedfight a few weeks ago, last week the engine seized on the way to school, when i took it apart the piston was completely fucked, first i saw there were lots of dents at the top off the piston and the head of the engine i thought a tiny rock somehow got in my engine because a few days prior my air filter came of and was lost so i had to rid it home very slowly without on on at all, but then i got on but it wasn't the exact same one.
When i took the piston out the top ring was worn to fuck so it had no purpose and to bottom one was broken and a bit of it was missing, also the skirt of the piston was shattered and there was a huge chunk missing, obviously the fragments from it caused all th dents, but i need to know what caused this problem as i am buying a new kit and really cannot afford for this to happen again.
I was told that my jetting may have been abit lean(i didn't do it) and caused the engine to overheat, however the problem i have it that there is no number on my jet so i do not have a clue to what size it is, also i have a manual choke which i left up on the first start of the day and get a syringe, take a drop of petrol out of the tank and inject the pure petrol into a pipe that it right where thee intake it past the carb and everything so that it starts first time everytime, could this bee sum sort of pre-ignition thing that could cause a seizure? Also i was told that changing the air filter could have fucked it up, but its not that much of a difference it as both were of similar size? Or could there bee another factor?
Any insight would be much appreciated, thanks!
