now now, im the only asshole allowd on the site!! LOL
thats an absoloute bargain and im sure you know it.. go for an iron kit, prefably polini for now.. strong, last forever (if setup correctly) and simple.
if your plans are somthing a bit more wacky read up a bit in the other posts
Yeh i think im gonna go for something a bit more wacky lol,
ive done loads of reading up about both iron and alu kits and setups, but i just really dont want to waste alot of money on the wrong setup etc,so im just looking for some guidance from more experienced guys...
ok... cylinders are cylinders.. good well known makes are reliable and of course cater for every need/desire from an engine. there are cheaper cylinders but most of them are shit, not to say theres not a good one here an there, its a case of askin people what they have used and liked.. theres a wealth of knowledge on prittymuch any setup from the tame to the wacky..
first things first grab a decent crank and figure what cylinder you want to run befor deciding on a pipe.. forget the rest for now.. crank, barrel, pipe are THE most important things to buy. the rest just make use of these items.
lol word spreads fast,thing is i also have an aprilia ,so instead ive decided to just sell the piaggio and work on the aprilia! hopefully change this page to an Aprilia project page soon enough,il be doing the same things to it though,70 kit etc..
Yupp sure,i bought the bike and everything was running like a dream,then a couple of months later im riding it down a hill,i get to the lights at the bottom of the hill and it cuts out!!!
i jump off and kickstart it again making sure i kept the revs up,the lights changed to green i went to pull away and it cut out again,i then started it up and left it to tick over at the side of the road for 15 mins,after this i just managed to get it home,making sure i didnt let the revs die down on the way home!
that was nearly a month ago,now it wont start at all!
ive bought a new spark plug and spark plug cover and coil,and have also cleaned out the carb....i dont know what to do next!
Its derestricted with a leo vince zx pipe and the rollers and springs that come with it,yes ive cleaned the carb and the air box out throughly, the only thing i can think of is if the reed's are damaged?
im really quizzed about this one tbh,dont know what to do!
Im currently having fuel issue's myself. I checked everything fuel related and even changed the carb without success so what i would advise you do is check yeah your reeds etc but also just have a look what colour the plug was before it went.
If you didn't upjet when you fitted the leo vinci you could have had a heat seize, this happened to me many moons ago
