Hi there,well im gonna do up my area 51!
Im gonna do some work to the engine,70 kit,bigger carb,possibly new crank depending on how hard they are to replace??
Im looking at a lot of parts just now,but i want to try and stay with the stage 6 brand,wise move?
here's a pic..
Image no longer available
OK so i have a few ideas for the 70 set up
first set up:
Malossi X Special Kevlar Belt €20.68
MF30.16605/12 Crankshaft Motoforce Evolution 12mm Gudgeon Pin €95.88
S6-3219066/RB Reed Valve Stage6 NBR €36.66
S6-35021BL Stage6 Double Layer Racing Air filter €29.14
S6-30DEL-19 Stage6 19mm Dellorto BE €84.6
LM7080526 Spark Plug NGK (short-threaded) B9ES (W2CC) €2.63
S6-7019501/R Cyl. Stage6 Racing 70cc (12mm)
Total Cost:£372.88
Second Setup:
Cyl. Stage6 Streetrace 70cc No Stock €121.26 -They dont have this cylinder in stock,so could someone recommend a cylinder with roughly the same price/power that i wouldnt need to change the crank on.?
M6112730 Malossi X Special Kevlar Belt €20.68
S6-30DEL-19 Stage6 19mm Dellorto BE €84.60
Total Cost:£243.87
Note both setups will be run on a leo vince zx pipe?
Any input would be appreciated
thanks lad's
here's a pic..
first set up:
Total Cost:£372.88
Second Setup:
Total Cost:£243.87
thanks lad's
