Hey guys, I'd like to introduce myself to you people Name: Marcel "Jiz0" Thiery Born: May, 8th 1997 in Merzig, Germany. Age: 16 Living in: Koblenz, Germany. (postal code 56068) Ride(s): Piaggio NRG Power DD / Aprilia SR50R Using my scoots for: The NRGis used for DSSC 150m sprints or trackdays / SR50R is daily driven Other activities except for anything including the scooter: as good as none. :c I'm glad my mate Omar (alias Subw00fer) introduced me to this place, pretty fine shack here :b
welcome again Marcel did notice your username was 'ramo', so thought you may have been called Omar aswell
Hallo und wilkommen, wie gehts? hehe, I'm from holland and yeah i speak some german. Thats a distance, had to go to koblenz a few weeks ago with my work. was 166km's to get there, and had to go back an hour later hahaha. nice place there, like the difference between the hights. Whats the setup of your nrg? Maybe you see me next year on the customshow in koln or saarbrucken, or maybe on some Dssc sprints. Did you already posted your project? getting a little curious.
He's got some stuff coming up, but he's been too busy to post on here i'll make sure he updates the project thread soon
Thanks everybody for the Nice welcoming Yeah ramon I've got a thread started here, you can see it in the projects section Yeah I am going to show off my ride on the custom show in Köln (Neuss) in Mannheim, and in Saarbrücken ! And take part in some DSSC and HBO events Maybe we can meet at the German Racewars next year ! My setup is Engine: Hyper2 LC DD Block Overflow and Ported by myself Stage6 Racing Mk2 Ported by myself + S6R/T 70cc Vertex Piston (A) Athena Racing HPC Crank finely balanced by `MTC´ Italkit Evolution Ignition Yasuni C20 Exhaust with Aluminum Muffler Stage6 Racing NBR Reed Valve Overflow Tune by myself Pro Porting Spacer + Inlet Overflow by myself Koso Powerjet Carb 28mm Overflow by Worb5 Stage6 Double layer airfilter Malossi MHR Overrange 2000 Variator + Torque Driver Malossi MHR Fan Pulley Drive Stage6 R/T Oversize Drive Belt Stock Transmission 13/46 Gears Top Performance Nardo Gearbox cover Suspension and Drive Gear: Stock Fork lowered and Stiffned YSS x-pro shock absorber with white Malossi RS24 Spring Aerox Wheels front & back with a 120/60/13 Metzler R-Teen on Front and a 140/60/13 Metzler R-Teen on the Back Brake Components: Stage6 SSP Oversize Brakedisc 280mm (front) Stage6 SSP Floating Brakedisc 180mm (back) Stage6 R/T 4-Piston Brake Caliper (Hard Adonised) Mk1 Version on front Aprillia SR50R 2-Piston Brake Caliper on the back Brake Pumps and Hoses from Aprillia (hoses to be replaced by Steel-flex soon! Optical: Cuttings on the Front Cover Smoothed and Cleaned Legshield Smoothed and Cleaned Rear End (Monoseater is being planned not sure tho) White Frame Oxygen H²pr0 Stem Selfmade M-Handlebar (aluminum) Thorns with threads to close up the Mirror threads Stage6 Cooling style brake pump covers Stage6 Adjustable brake levers (soon to come)
we'll see about meeting there, still have a lot of work to do and make some changes on the frame. Have a fronfork know, but well, aint gonna fit with the rad on the front, so need to place the rad somewhere else... A lot of work, hope its gonna fit, we'll see
