If main jet controls the air in the carb why do i need to change jets if i can adjust the air from the air screw?
Jetting?
Main jet doesn't control the air in the carb, the air mix screw controls the air to fuel ratio flow through the carb.
There is a couple of threads that tell you how to set up carbs properly on here, have a trawl through the tuning section. Loads of great info there.
Main Jet controls fuel flow from around 3/4 - full throttle. The air/fuel mixture screw only effects the Pilot Circuit, which means that it only effects idle - around 20% of throttle.
Have a dig around the tuning sections, plenty of jetting guides on there
with 3 turns out(not full turns) its like struggling at 1/4 throttle but runs great when i open the throttle more than this, so i screwed 1 more turn out and was running great at 1/4 but after riding a few mins the spark plug was getting oiled too much.Do i need to rejet the carb?
| Standard pilot jet size for Nrg power | 18 Dec 2013 |
| Aerox help | 17 Dec 2013 |
| Beta Ark LC Tuning | 15 Dec 2013 |
| Aerox tuning issues | 15 Dec 2013 |
| Tuning help | 11 Dec 2013 |
| 172 add ons | 9 Dec 2013 |
| Generic Cracker main jet. | 8 Dec 2013 |
| aerox shenanigans | 4 Dec 2013 |
| Peugeot speedfight 2 | 4 Dec 2013 |
| Balancing Transmission Setup | 2 Dec 2013 |
