Scooter Shack Scooter Forum
Help, Help, Help, Help !!!
Discussion in General Scooter Discussion started by mattyt, 14 Oct 2013
mattyt#1
Hello there, i have recently purchased a Gilera SMT (Derbi senda) 50cc but it has a Derbi engine in it at the minute.
Basically when i rode it back from where i purchased the next morning, there was a small puddle of water on the garage floor, upon inspection i noticed there was a small hole in the engine, (very tiny) letting this water out, i realised that the temp sensor was long gone, and this was obviously the problem, so i bought a new one, fitted it and still, i am getting this puddle of water on the ground shortly after i use it.
Now is this tiny pressure outlet hole literally the size of a cocktail stick meant to be here? As this is where the water is coming from.
mattyt#2
PS, its watercooled and i am slightly worried as i don't know to much about bikes, and i haven't got the time or money this month to take it to a garage, it runs perfectly though (although needs carbs rejetting).
PDBV#3
I wouldnt have thought it is supposed to be there doent sound right to me, are you 100% sure there is a leak and its not just water collecting from the road ?
If it is a leak i would change for new if thats possible, a picture would help :)
Sent from my GT-N7100 using Tapatalk
mattyt#4
Its definatley not water collecting from the road, i can see the water droplets coming out of this tiny hole, but in this case looks like a new engine, though i definately want to know if it is ment to be there.
Stevep#5
Yeah, a photo would help. Is this hole on the right hand side of the engine near where the pipes attach to?
It could be the water pump seal starting to go and leaking out the hole that is SUPPOSED TO BE THERE.
But photo please:D
mattyt#6
I will get a photo, apparently its a weep hole
PDBV#7
I stand corrected cheers steve never had an lc scoot before but tried to help anyway :)
Stevep#8
Ok. Then if it's weeping out of that hole the water pump seal is on the way out and needs to be replaced.
DO NOT UNDER ANY CIRCUMSTANCES BLOCK THIS HOLE UP WITH GUNK OR MASTIC OR ANY OTHER SEALANT
If you do it will eventually flood the case behind it and then you get water all over the generator windings and pick up coils and flywheel.
And then total electrical failure and nice deep pockets full of money to throw at it.:D
But a photo would be nice first;)
TNT headlamp2 replies19 Oct 2013
Very surprised :D0 replies19 Oct 2013
Master Cylinders0 replies19 Oct 2013
Hydraulic presses and scooter cranks3 replies19 Oct 2013
Sorting out 30yr.old wheels.9 replies17 Oct 2013
TGB Hawk 125cc12 replies14 Oct 2013
Piaggio engine compression?5 replies12 Oct 2013
Remember this little project of mine...............9 replies12 Oct 2013
Peugeot Speedfight Rear Brake0 replies12 Oct 2013
Am I Being Too Generous With What I do?19 replies12 Oct 2013
