Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
Help choosing air filter and crank
Discussion in Scooter Tuning started by NickForcer, 31 Dec 2014
NickForcer#1
Where i live now its winter and there are many rainy days so will i have a problem if i use this filter "Stage6 Double Layer Racing Air filter" can you suggest me any other filter (covered preferably ) for my setup ;; I have a gilera runner 50sp 2013
My setup
Stage 6 racing mkII cylinder
Stage 6 R/T VHST 24mm Carb
r-setup 14k exhaust
Stage 6 intake system
Stage 6 R/T MKII crankshaft (Also what do you thing will be better for my setup an 80mm conrod or an 85 one)
I havent ordered anything yet waiting for suggestions...
Thanks for reading and sorry for my english :/
Nathanael#2
Those filters are fine. Make sure you have room to fit it and that when suspension compresses nothing rubs on it or you will quickly wear holes in it. I run one and keep a plastic bag over it when scoot isnt being ridden to keep the moisture off.
Malossi E13 isnt a bad filter, its compact and covered. Dont buy the copy version of it though, the outer cover has a tendancy to fall off once it has been removed a few times
scubabiker#3
i actually went back to my standard airbox on my scoot after my filter kept getting wet, but we get considerably more rain here than in the uk i think. but like nathanael says, just be sure it doesnt rub anywhere, or you will have major problems (im a guy who rode to italy with a bracket rubbing a hole slowly through his tank)
NickForcer#4
haha thanks both of you i may keep the airbox and mod it :)
scubabiker#5
you need to make sure the intake into the airbox is equal to or greater than the carb diameter, or you will choke it off
helo2 replies10 Feb 2015
2001 Yamaha Neos, Best Way To Make It Fast?3 replies6 Feb 2015
Peugeot ludix jet size to get to run without choke0 replies28 Jan 2015
Yamaha Neos 50 2 stroke Best ways to 70cc it?0 replies27 Jan 2015
NRG Power running really bad after fitting stage 6 pro replica exhaust? please help1 replies16 Jan 2015
Aerox Set up! help!1 replies12 Dec 2014
Aerox Brake Bleeding Help?!4 replies7 Dec 2014
jinlun jl50qt-4 ( peugeot v-clic rep)7 replies24 Oct 2014
honda x8r setup0 replies21 Oct 2014
Speedfight 50LC setup11 replies17 Oct 2014
