Scooter Shack Scooter Forum
A/C to L/C
Discussion in General Scooter Discussion started by Burns, 4 Apr 2008
Burns#1
how much work is involed in converting a piggy a/c to a l/c is it just water pump, head and loom? or is there much more than this?
kyle1b1#2
dont think a ac to lc can be done as far as i know but a lc to ac can be not sure tbh :rofl:
MiNoR cOnFuSiOn#3
easy if your using an eleci waterpump.. can just drill under the exhaust port on the barrel and tap for a pipe fitting and feed water from the top into this.
or machine out the section that usually houses the waterpump. a bit harder and why not just run an electric pump
Jamie#4
easier to do lc to ac
just fit the ac topend, tap the stator so you can screw a fan onto it. then fit the cylinder cowl.
Haresign#5
don;t even need to tap the stator, the holes are already in it.
Sw1fT#6
without thread
capri dave#7
scooter attack sell ac to lc kits for the minarelli ;)
Burns#8
the engine has got a water pump on it already and comes with a lc head.....do i just bolt the head on and away i go or is there more too it?
would like too know before i buy it and it turns out usless
nrgandy#9
Sw1fT said:
without thread
not seen many piaggio 50s then every one ive worked on the fan holes have been threaded on a/c and l/c
Jamie#10
if you talking about the hole in the middle thats threaded thats for the flyweel puller to take it off.
MiNoR cOnFuSiOn#11
the 50's have the same flywheel so i belive there all threaded.. the 125 items are diff between lc and ac tho.
Sw1fT#12
yeh, it wasnt stated whether it was a 50 or 125, 125s arent threaded.
seen plenty of piggy 50s thankyou very much.
Side Stands4 replies8 Apr 2008
How do you wheelie?23 replies7 Apr 2008
phgb 19 carb2 replies7 Apr 2008
08 Jog RR ??DERESTRICT??13 replies7 Apr 2008
yamaha slider good or bad5 replies6 Apr 2008
variator washer3 replies6 Apr 2008
?????rev limiter????1 replies5 Apr 2008
gianelli extra sports exhaust?1 replies4 Apr 2008
how to post pictures1 replies4 Apr 2008
Broken my foot4 replies4 Apr 2008
