I think it might be. I got it new, but it was in a yasuni box. I ordered the NONE though. I dont know...
2 more pics. This thing must run about 65mph. I will have my buddy with his 5.0 mustang clock me tomorrow.
what?! Wait a second. What are your mods Zumaman? Can you list them? You're not running a LC EVO are you? The reason I'm asking, is I've got a Corsa/R also and I'm topping out at 50mph. Just trying to figure out where the difference in setup is.
K, I have the following; Polini Corsa/R Yasuni C16 with technigas can Kundo Supersport crank C4 SKF Bearings O/R tranny 2G clutch 1500 tourq spring Speedbell Arreche Racing Airbox 19mm arreche Clip in middle notch (if I remember right) 90 main Jet .30 Carbon Tech reeds 5.0g rollers NGK BR8EIX plug I am unsure of the gearing; whatever came with my cases You should be hitting atleast 60mph. I doubt the crank makes that much of a difference? Anyone have any imput on cranks adding anything? I know the primary compression will go up, resulting in better bottom end power. I am going to PM you, Chris.
Hey guys, what would cause chopping in and out after a 10-15 sec run? I go WOT for awhile, let off the gas, turn arround, and when I hit it again, it boggs. I have to wait for the bike to idle down; then when I I hit it flies again. What causes that? Fucking Arreches?
float not filling up quick enough,... possible fuel tap malfunction, leaky carb or just small fuel pipe/sticky float. deffo float related tho
I feel like a dumbass. You're a genius, Minor!!! What should I do? Could it have something to do with my gas line? Could my carb be too small for my setup? The bogging doesn't happen unless I run W0T or so for a few secs. ANY info would be great! Thanks again, confusion!!!
Fuel pump? Something stuck in the line? This brings up a good question. What's the best way to test if your fuel pump and oil pump are working correctly?
Get rid of the oil pump and run premix. I dont think their is a pump for gas on our zumas. It is gravity fed, right?
