Sr 125 ac lump fits in a zip frame with no modifications? Dont want to jump up and spend £200 without checking :blush: I know typh engines fit but i dont want to put any work into the frame, as i want to be able to change it back.
You had to mod the engine mount and completely rewire the bike using a typhoon 125 loom which are very rare. You also have to change the engine bushes on the sr engine as they are solid due to a different mounting system used by aprilia and you can only run a big drum typhoon wheel on the rear or the huge sr rim. So no you can't just slot it in and to change it back you would have to swap the loom and the engine mount.
