should fit ok as they had the same headstock but the bearing might be different...could check part numbers to confirm. you'll also need the speedo cable (which I believe is different from the 2 fork model) and front mudguard
they are a straight fit just need the speedo cable, front mudguard and the little protector bit otherwise the forks look funny
