Hi mate charging the stator today but I still get that nasty take off From cold is good I’m on a 85 main jet standard box some just inbox me saying out 90 in surly no way really need some good knowledge heads
Upjet. If its better when it's cold, that means it's better when it has more fuel. Upjet is more fuel. Try a 90 or even a 92
Even tho I’ve got the standard box mate yes when it’s cold manual chokebtw it’s pulls away perfect untill warm up Then it’s not good If sometimes I slowly rev and or keep revs up she goes but splutters I’ll try 92 tomrrow and 90 I have to hand
Can’t upload a photo well I’ve put 3.6 g rollers in made it better but still can here that take off hesitation Stator made no difference Also I’m a little bit confused on your reply mate you told me to upjet if it was getting too much fuel once warmed up woundnt that cause it to splutter and going bigger would make it worse
Right then I’ve put the rollers in 3.5 g and it’s improved it a hell of a lot but it still got that kind of starter from takeoff I read understand why I haven’t updated as you said above but wouldn’t that make it worse up jetting I know you replied back to when I said about from cold I don’t even have to use my choke manual just started in cold weather
When it's colder it draws more fuel in and runs richer because it doesn't burn it all. Its thermal dynamics and complicated to explain
Morning buddy okey the. Well if I go out there and try 92 or 90 then it still does it then where do I go ? Yes from cold I normally let it warm up at least five min and not hammer it and it will pull away for sure with slight chokey sound once that’s come off I can pull away soon as temp gets to 40 on Speedo it’s back
And btw the way I found a thread on here and cannot find it user mr bizzle states same kit and set up as mine and his take off was arsehole same carb Now I’ve noticed something he states........ His pilot jet was 27 that’s not the size that in mine I’m sure it’s 37 this could well be why it’s doing it up to half of throttle I’m trying to find the specs of mine online Can’t find it’s Delorto 17.5 carb manual choke The main jet was 90 inside I can’t remeber exactly the pilot jet size I do recall putting the 90 back in and was the same It’s crazy tho how the lighter rollers made it less splutter on take off but can’t go any lighter than 3.5g
Right then My 17.5 carb Has a 34 pilot jet I’ve spoke to Pedparts he sent me this link For pilot jet https://www.pedparts.co.uk/product/6307/idle-jets-phva-phbn Now then the photo below shows another jet beside my main jet that I fort is pilot jet but it’s nithing to the link ablove as that looks like my choke I’m getting confuse reason why I want to know is that I think the pilot jet is to big along with the 85 main jet inside hints the splutter
Pilot jet has the emulsion tube bit (it's long with holes along the side) Choke jet is more like the main jet, just a sort of screw with a hole in it.
Okey perfect I understand that now we’ll im going to try the 32 that’s the lowest Pedparts sell and I can’t find that any where else it’s worth a shot I think
Wel I’m back again the problem is still there 92 main jet 1&half turns out so fast but sometimes takes off is shit . Snokal is removed I’m not sure if I should try 95 or 100 Main jet I did try 86 today and seem much more responded on take off but didn’t seem As quick mid range but less problem On take off confuse confuse
