Yamaha aerox help needed!!!!
Discussion in 'General Tuning' started by Jimmy yates, Jun 9, 2012.
  1. Jimmy yates
    Jimmy yates Member
    Did he have to set up all the ignition timing and stuff again?
  2. fastfuel
    fastfuel Member
    suzuki 125 rg gamma
    u dont need the 2 nipples block them off its only too warm fuel up but we really dont ever get that cold the fuel frezzes cold fuel will make it run better
  3. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    No, theres no adjustment in the timing, the plate simply on bolts and bolts back on in a fixed position.
  4. Jimmy yates
    Jimmy yates Member
    Oh right, So it's a fixed component untill you take the stator off the flywheel, So it just slides off, seems easy enough lol
  5. Mr Bizzle
    04 Aerox 70 stage 6
    Yup, simples it just bolts on and off.
  6. Jimmy yates
    Jimmy yates Member
    Mr bizzle, My water pump wont come off as one of the bolts have rounded off... Ffs, So I can't put my stage6 pump on, Will the streetrace be fine cooling on the standard pump?
  7. Mr Bizzle
    04 Aerox 70 stage 6
    Should be fine.
  8. Jimmy yates
    Jimmy yates Member
    Have you got a upgraded water pump? Or anything done to keep it cooler?
  9. Mr Bizzle
    04 Aerox 70 stage 6
    I just fitted a new pump and run it with a high concentration of antifreeze/ summer coolant.
  10. Jimmy yates
    Jimmy yates Member
    I was going to put a stage6 pump on and 1 of the bolts rounded off so I can't get it off.... So I'll just have to leave it for a while and get a garage to change it
  11. Mr Bizzle
    04 Aerox 70 stage 6
    Is it one of the allen bolts that has rounded?
  12. Jimmy yates
    Jimmy yates Member
  13. Mr Bizzle
    04 Aerox 70 stage 6
    Give it a tap with a hammer to loosen it , then grip it with mole grips to get it turning. If you cant get the grips onto it use a solid screwdriver and tap it around like a chisel, it should loosen easily.
  14. Jimmy yates
    Jimmy yates Member
    What do you mean by tapping the screwdriver around? What a Phillips of flat head?
  15. Mr Bizzle
    04 Aerox 70 stage 6
    I meant using a flathead screwdriver, simply hold the blade to the head (not yours, the bolt!) and give it a couple of taps to make a little groove. Then angle the screwdriver to the right so it's at about a 30 degree angle and start tapping it whilst applying a pressure leading it anticlockwise. it should come off but the bolt will be nackered (it is already).
  16. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    Mole grips worked for me , had the same problem......3 bolts, got 2 off and just so happened the last one was rounded o_O
