Will i need a performance crank?
Discussion in 'Newbie Scooter Tuning' started by PedBoyEd, Jan 29, 2012.
  1. PedBoyEd
    PedBoyEd Member
    oh and when you say heat cycles you mean let it idle and warm up then switch off and cool down again a few times?
    cheers
  2. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    Heat cycles are 15 minutes or so of gentle running and then letting it cool down completely ;)
  3. PedBoyEd
    PedBoyEd Member
    ok so just have it on its stand and give it a little rev or take it out for a short spin ?
    cheers
  4. FiddyRox
    Ride it mate
  5. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    i always let it warm up by ticking over the very first heat cycle
    second cycle a bit of revs on stand
    third cycle take a easy ride up and down your block
    fourth cycle ride round the estate
    then once thats out the way thrash until the wheels fall off
  6. PedBoyEd
    PedBoyEd Member
    haha good progressive run in and ill over jet slightly so the cylinder is well oiled etc.
    cheers for all the help, ill put some vids up and pictures in the project section around friday/saturday
  7. PedBoyEd
    PedBoyEd Member
    just one final question, to take the whole engine off the swing arm will i need a torque driver or is it just a hand wrench jobby ? because i dont have a torque driver and they are £30 quid to hire for a day from hss unless anyone wants to lend me one ?
    much appreciated
    Ed
  8. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    dont have to ... but it might be a bit tight and you would want some locktight and use a breaker bar when tightening it up
  9. PedBoyEd
    PedBoyEd Member
    ok cheers for that ill let you know how it goes ! :)
