Hi all, I've bought a Vivacity 3 with a known problem of the indicators not flashing. It's a 2016 (which is strange as everything I've read says they stopped making it in 2014). I've had all the panels off and can't for the life of me find a relay. I don't think it's built into the regulator as that only has four wires to it. Has anyone got a wiring diagram (or a similar scooter and listen where the click comes from). Thanks, Steve
Okay - for the benefit of future readers I've fixed them. Basically the relay is built into the digital instrument cluster and isn't replaceable. Mine had failed leaving a permanent +12V going to the switch (so the indicators could operate with the ignition off but didn't flash). So I disconnected the switchgear plug and worked out which pin had +12 on it with ignition off, cut that wire (on the switchgear side as that could be replaced easier if it all went bad) and patched in a two pin relay bought from ebay for a fiver. Job done!
