un problemo 0.0
Discussion in 'Bike Chat' started by frainey, Dec 11, 2007.
  1. frainey
    frainey New Member
    Cheers wobbly i think that might be it as i did set them myself (Or tried too)
    Inlet and outlet to 0.05mm didnt crank the bike over while setting it too :emb: :wtf:
    Il get my brother to set them on sunday, he rebuilds 2T motors for a living.
    Will having them too tight explain the bogging ?
  2. wobbly_trials
    ok, i would set them to 0.2 mm to start with (when both valves are fully closed on compression stroke) this is slightly sloppy but they do tighten up on a new engine.
  3. J-Nitro
    J-Nitro Active Member
    yeh thats a point check the clearances
    im sure one valve has to have a bigger clearance than another tho??? o_O
    check for coke deposits too as this could restrict the intake part
    if all the suggestions listed fails burn it and get a scootay... :pimp:
  4. wobbly_trials
    yeah exhaust gap is usually a slight bit more as its hotter. but on a gap as large as i suggested it won't matter.
  5. hotwot
    hotwot New Member
    This happend to my mx copy bike..
    It will idle (rough) but as you rev it sounds like its choking but wont bog down and cut out it will just choke but will still hold the revs while popping and white smoke going everywhere :rofl:
    I loved that bike!
  6. fuj_yammy54
    fuj_yammy54 New Member
    it just sounds really cammy. exhaust tappets havin a heart-attack. TING TING TING! :w00t:
