Hi guys, got a typh 125 2 stroke. Im a paint technichian so started the paint work as you can see in the pics. Its all standard apart from the 25mm carn and runner 180 exhaust. It was running perfrct. It cut out a few weeks back now it strts every now and again, ive replaced the plug, the ht lead, the cdi and it started then cut out again. Ive added pics for any help??
Put a good ngk plug cap on it, not the lawn mower type. That coil look's wrong? are you using a vacuum petrol tap or manual?
I know it looked strange to me, i tried the ngk plug and did exactly the same just cut out . Its a manual petrol tap
Ive changed the stator plate too, i also changed the coil to another new one, started up first kick for about 2 minutes now died and wont start again. Im debating putting a new loom in if i can find one, thanks for help man all i want to do is ride the thing
would this be good spec set up for piaggio zip ac? - Stage6 chrome exhaust - Stage6 21mm R/T MK II PWK racing carb - Stage6 SportPro 70cc aluminium cylinder kit - Stage6 19x15.5 variator roller box set (6.5g to 9.5g) - Stage6 drive belt - Naraku HPC racing full circle crankshaft - SKF crank bearings / seals C4 - uprated race
