Hello, guys, I am looking for perfectly regulated transmission because when I start accelerating from zero I have very slow 0-5mph and then it just opens up and goes normally. What rollers and springs I should use? My setup: Dr. Evo 70cc Dellorto 17,5 carb stage 6 sport pro variator with 5g rollers Malossi delta clutch with Malossi white clutch springs(4000rpm) and red torqdriver spring Malossi wing bell It's very annoyingly when I lose in drag because of that shitty start Please help me
I tried stronger springs, didnt felt any difference, I am just wondering maybe someone else know spring and roller setup for my setup
Sorry cant give you a straight answer. Maybe this video could sort it out. And maybe the reason to why chainging the clutch spring didnt seem to make any difference from scooterswapshop: Simply put. Might be to heavy rollers making the clutchbell spinning into higer gear before the clutch engage. But id get a wide assortment and dedicate a few hours, and just try different. Rollers. Clutch. Springs and contra springs. Until you found the sweetspot you looking for
