TPH Part Selection
Discussion in 'General Scooter Discussion' started by The General, Nov 19, 2007.
  1. MiNoR cOnFuSiOn
    because the topic's made with @use the search@ obviously have been asked where this hasent. ether way its been said now. posts dont need to be re-made every month because people wont search, and if your told to search its usually because weve got 3 posts the same full of answers already.
  2. Dunney-LFC
    Dunney-LFC New Member
    I am a member of pug-club, scooter-shack, aprilia forum and gilerarunner.net and to be honest, all the search functions are sh!te and do not function properly.. You really have to get lucky with your choice of words..
  3. tErr0
    And who makes it hard? All the people who type in text speak and all the people who don't use relevant topic titles.
    Also people spamming up each topic with pure waffle doesn't help.
    The actual search function is completely fine.
  4. MiNoR cOnFuSiOn
    correct.. if you search via title with one keyword and find nothing its because people name there topics silly things to try an "trick" people into reading them when they know people dont wanna read there shit about there broken chineese peice of shit...
    so everyone get relevent an drop the waffel. its not just us being picky. it makes the board work properly. ive never had a problem using the search. computers only od what you tell them too
  5. Dunney-LFC
    :w00t: :w00t: :w00t:
  6. The General
    The General Member
    Does this carb have an oil valve attatchment or will I need to drill one?
    What should needle height be set to and what about idle mixture? (considering my setup)
    Cheers :tup:
  7. The General
    The General Member
    I've heard of people making holes in their carbs for the oil and petrol to be able to automix or something?
    Can anyone tell me if I will have to with this carb? It hasnt come thru yet so I have no idea and ive just cancelled my order with SC they are takin the piss!
  8. kyle1b1
    no you dont have too. can see the oil nipple on that pic :w00t:
  9. The General
    The General Member
    ok sound bud
  10. The General
    The General Member
    Minor when you suggested an 86ish jet did you take into consideration the polini open air filter mate?
    Cheers
  11. MiNoR cOnFuSiOn
    sommin like that.. mabey lower. dont confuse rolelrs with jetting tho. it will run wiht an 86 an filter so if it refuses to drive at full throttle play with the rollers
  12. The General
    The General Member
    Thanks for that minor put an 86 in there and it worked perfectly, it flies now
    The only thing is there is no choke :confused:arc:
    What do I do buy one of the tubes with the little lever on the end or..?
    I'll see how hard it is to start from cold but my mate that setup my bike was screwin cus there was no choke and saying i shouldnt put it on cus its gonna be a bitch to start in the morning so he jus stuck a screw in the valve where the chokes supposed to go I think.
