Scooter Shack Scooter Forum
Stuck
Discussion in General Scooter Discussion started by Stage6Pro, 28 Aug 2010
Stage6Pro#1
I recently blew up my speedfight 2 bore kit and when it happen 2 bits cracked off the piston and obvisiouly ended up in the crank case ... now i have taken the engine out and theres no sign of these 2 parts? i flushed it through with some petrol do i take it that they have ground down to tiny bits ..?
i dont want to put my new cylinder kit on if theres a risk it could damage it ?
please help
GUNS#2
you have to consider what sized particle, it takes to scratch a bore, basically minute.
I am no expert, and there are some experts here who will comment......... if it was me I would be splitting the cases and changing all the bearings, as my fear would be either the ground up residue is clinging to the bearings, which will knock them out in no time, or the residue surfacing and scratching the bore. My method would include basically a surgical clean of all the parts.
If it comes to my advice, how many k have the bearings and crank done anyway? If they are orginal, you get a bottom end to match the top.
Why did the big bore kit let go, was you over-revving it at the time?
capri dave#3
to do the job properly, i would go with Guns advice, its a bit of a pain i know, but if a piece of old piston resurfaces youull be stripping the engine again and forking out for another kit....
first ped what should i be looking at?10 replies2 Sep 2010
filling up11 replies2 Sep 2010
rust prevention?3 replies31 Aug 2010
Frame Numbers13 replies29 Aug 2010
zip headlight3 replies29 Aug 2010
Piaggio Engine 125cc 4 stroke leader5 replies27 Aug 2010
Gilera DNA 125 Performance Parts1 replies27 Aug 2010
Gilera Ice fork seals1 replies25 Aug 2010
rollers1 replies24 Aug 2010
Stage 6 website.4 replies24 Aug 2010
