starter button broke
Discussion in 'The Workshop' started by Kev Clark, Mar 30, 2016.
  1. romain
    romain Member
    Yamaha tmax
    On a multimeter you can check for continuity
    But mainly for voltage
    Like if you check your battery you connect you multimeter on parallel and you get a volt reading usually between 12.2 & 12.6 V
    To check if you have feed to your switches
    Fit one end ( the black one) to the battery earth or any earth point on your bike
    And you disconnect one of your brake switch (two connection)
    One of those connection should be be your feed and the second should be the consumer side (the direct link to your brake light bulb connection)
    Let me know how you get on
  2. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    ok il try that thanks, got a new bulb and its not that grrr
  3. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    the reading on the left 1 are 12.53v and the right 1 is 12.55v
  4. romain
    romain Member
    Yamaha tmax
    Ok so now you know you have a good feed on your brake light switch
    I take it when you say left right you mean rear brake switch and front brake switch?
    And that is only on one of the connection of each brake light switch connection?
    Kev Clark likes this.
  5. romain
    romain Member
    Yamaha tmax
    If so you need to link the rear brake light switch ( get the two connection together use a piece of wire or paper clip)
    Watch out if it s a paper clip not to touch the earth with it and check at the connection I mentioned which is in the loom around 10/20 cm away from rear light assembly and see if you have two 12.53 V
  6. scubabiker
    romain is the man! i think me and stevep can retire now!
  7. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    Yes each switch on the front left& right brakes I meant mate. Il check them when I get back home in a few hours I've had to do some work haha cheer romain your the man! Hopefully get an answer later
  8. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    Sorry forgot to add yes I only got a reading off 1 wire on each switch. The other didn't give me a voltage reading
  9. romain
    romain Member
    Yamaha tmax
    Cool no problem
  10. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    Right I couldn't seem to get a voltage reading off the back but get this I screwed the bulb in a different way and now I have brake lights but no rear light and vice verse when I put the bulb in another way. Weird ey
  11. romain
    romain Member
    Yamaha tmax
    If you couldn't get live at the back that mean you have no continuity on the line
    So you either didn't check the continuity correctly or you haven't got 12.53 V going across your brake switch bypasse ( paper clip or piece of wire)
    Or while doing so you blew a fuse check again your feed at the brake switch
    Now regarding your bulb, your initial problem was you have no brake light but the rear light work fine,
    You probably can fit the bulb either side due to poor built quality of the rear light assembly but it should go only one way
    Your bulb being two filament you either feed the rear light side of filament or the brake light side filament but you still only have one live I take it ?
    Don't forget being methodical is the key !!
  12. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    Hello mate sorry about the late reply I've been working all day and haven't had a chance to look at the bike. I've been to work and back on it tho and it's riding fine it's just the no tail light problem. Do you think it's the regulator or solenoid or just a bad wire? Sorry to be a pain but could you explain again how I test for continuity on the wore again. Cheers bud
  13. Kev Clark
    Kev Clark Member
    Lexmoto Zoom 2 125
    Hello buddy I've fixed it I now have brake & tail lights. All I done was bent the contact back properly and fitted the bulb an walla! Thanks for you help mate it's much appreciated take care. Kev
  14. romain
    romain Member
    Yamaha tmax
    Glad to hear you sorted it out
