Well I have now desided to not go for this Polini Evo 2, as this will cost too much money. I will fokus my money on the Typhoon project in stead. But you never know, there might be some small updates now an then.
Well, I have been checking the German Ebay from time to time, but I could'n find any C21 (which is the pipe I want). I have not been searching other forums, so if you have any good tip, please post the links
Got som new parts today. This is the "breathingcap" that Gilera has used on the newes Stalker. The "old" version has a closed engingcover, so this one will let it "breath"
only reason it needs to "breath" cleaner air is down to the cat, wich sucks in unfilterd airfrom the transmission case, through a valve then straight into your pipe (pipes send air back into an engine remember) cat's = bad news i recon, same emmissions, more air mixed in, pointless and kills your engine. i keep the rubber plug in, it works, never had an engine overheat a variator
Well the Stalker is in daily use by my son, and we will not do any update before the spring comes. (It's freezing here in Norway now)
I have been playnig a little with the thought of converting it to 125, since I have a spare engine. I have also recived a Gilera 125 loom with CDI and coil so everything should be ready to go. But then I have to register as a 125, and then my son can't drive it. What do you think? Tough choise.
mate can you do me a favour and get the dimensions of that platform? I went to get one today and i was like, no way can a ped go on that ? so pussied out
