Stage 6 prostreet USLESS!
Discussion in 'General Scooter Discussion' started by wedgie, Apr 16, 2012.
  1. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    80 would be a good place to start mate
  2. wedgie
    wedgie Member
    Mk 1 Zip SP
    Cheers mate, Should get it of a friend tomoz then after college ill see whats goin on! Cheers
  3. roxy boy
    roxy boy Well-Known Member
    roxi
    its a waste of time tp put a open air filter on a sport there is not enuf revs to need one
  4. kylerox
    kylerox Member
    my sport runs mint with an open filter on 21mm carb.92 jet in it. responsive and revvy too and not bad on fuel
  5. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    I'm running a similar setup, it sounds like your carb is seriously underjetted as soon as it warms up it is running very weak and hot. My bike would run with the standard 12mm carb only with a 70 main jet and the standard airbox, you will definitely do damage running without an airbox and unfiltered.
    I now run it with a 17.5 dellorto and I think it is either an 82 or 84 main jet, I've kept the standard airbox with a mallosi filter but had to remove the snorkel as it coukdn't get enough air through the restricted opening.
    The scoot now bites your head off and pulls 70.
    Have a look at the pedparts site and you will find that the 21mm carb is probably overkill with no extra gain exept bigger fuel bills on a streetrace. Fit with either a 17.5 or a 19mm with a standard airbox (maybe remove snorkel)
    you'll be grinning like an idiot.
    When you fitted the kit did you bleed the cooling system by slackening the small bleed valve on top of the cylinder head to let the air out, cos if you don;t it will trap air and may cause a hot spot.
    Most of all don't loose patience a little bit of fiddling and it will run sweet and fast.
  6. wedgie
    wedgie Member
    Mk 1 Zip SP
    Cheers mate it makes a lot of sence. I can get either a 17.5 carb or 20.5, It seems to be the 17.5 would be better from a lot of people so ill try that! Its just annoying as i need it for college lol The bike make me smiles for the first 5 mins as its insane of the line lol. when i get the carb ill messege you if you like and we wil lgo from there! cheers for the help!
  7. wedgie
    wedgie Member
    Mk 1 Zip SP
    Got bit of a problem now, When the bike hits 30 it flys round the clock but before then its usless barely moves ? any idea?
  8. Mr Bizzle
    04 Aerox 70 stage 6
    Variator/weights issue?
  9. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    does it just rev and not move, or does it splutter and go or hessitate explain what happens till hits 30
  10. FiddyRox
    If its the standard variator then buy a decent one, that's the problem. If not, try new rollers, and a stiffer contra spring in the clutch ;)
  11. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    are you still running the bike on poor jets? chances are your just screwing it up more and more fella.
  12. wedgie
    wedgie Member
    Mk 1 Zip SP
    It seems to be fine after 30? and had all difo jets in today the one im running seems to be ok? Im running a polini variator with 4.4g rollers and the big blue contrast springs with yellow springs they seem to be ok like i say after 30 but when hitting 30 there just like no boost lol like if it was a restricted bike or somthing, proper annoying me, If i cant fix it tomoz Im going to just return it back to a 50 lol
  13. Aaron Hastings
    Aaron Hastings 125 KiLLa!
    Mk1 piaggio zip sp.
    You are not putting the 50 kit on again!.. we'll get it running sweet
  14. wedgie
    wedgie Member
    Mk 1 Zip SP
    I want to come out tomorrow though :(
  15. Aaron Hastings
    Mk1 piaggio zip sp.
    Put the 50 back on until you get the 17.5.. :)
  16. wedgie
    wedgie Member
    Mk 1 Zip SP
  17. creamsodauk
    Runner 125 SP
    right so the bike now pulls slow to 30 then revs up after?
    have ou tried the stock airfilter and jetted again? if the bike is slow on launch you may need stiffer springs on the clutch. on my old aerox 100 i fited the stiffest mallosi did to get the revs up on launch.
    the clutch only matters for the first few seconds anyway then the variator kicks in. so if the bikes sluggish for a while maybe lighter rollers are needed to get the bike into its power band quicker.
    its all a case of trial and error
  18. Aaron Hastings
    Mk1 piaggio zip sp.
    it's got 4 gram rollers in at the moment and once it hits 30 it revs like **** so i doubt it wants lighter rollers in. i think it's something to do with the jetting :/
  19. CA Zip tuning
    CA Zip tuning Member
    put 5.5 gram in and try 70
  20. phil.s
    phil.s Active Member
