this is actually for my own scooter, not to fimilar with injection, put a 70cc kit on my scooter, won't fire up, it's the injector thats at fault as it fires up with fuel in the barrel.
going to get a new injector to try out but anyone else got any ideas?
you should have bought the correct kit for the ditec.. it has a new ecu. but yes. blank off the second hole in the case, bang a carb on an switch the wiring.. big mess of uselessness
the kit i bought is a polini, 3 years ago though! with it i got everything including the injector adjuster, which was a whole load of bloody o rings with no way of seeing where they properly!
if i can't get a cheapish injector, i'll convert it, sounds easy enough if i can use the same throttle cable etc which im sure i can.
wish i had just tried it first without adjusting anything! didn't have much of a clue with injection set ups though.
to conver it, i'd need carb manifold, carb. maybe airbox? and ECU?
