Speedometer
Discussion in 'Visual Modifications' started by rustyscooter, Nov 18, 2013.
  1. rustyscooter
    rustyscooter Active Member
    Aerox, Harley, Blade
    If your bike has been tuned and now exceeds the maximum MPH readout on your original speedo, have you changed the speedo to a different one to accommodate the speed you can do now, if so what have you changed it to.
  2. southweezy19
    yamaha neos!!
    Get koso or similar
    rustyscooter likes this.
  3. rustyscooter
    Please explain
  4. rustyscooter
    Yes Koso, sorry:)
  5. southweezy19
    yamaha neos!!
    No worries buddy
  6. scubabiker
    i have a bicycle one on the vf, it goes to 99 then back to zero, cheap as a cheap thing and works really well
  7. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    i bought a phone mount for my handlebars, i use an app for a speedo now:D
  8. Mark Emerson Trentham
    Used an old wing mirror with a broken glass,taped an old ready meal tray over it.cut out a hole an left one end open to slide phone in. :D.
  9. scubabiker
    i have a phone holder on my vf, but i dont like the idea of my phone falling out!
  10. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    mine sits in a sealed & strapped waterproof case
  11. rustyscooter
    how can you use an apps for a speedo
  12. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    works via gps, tells you altitude, distance, max speed etc
  13. rustyscooter
    How accurate is it, is it good enough not to get caught on camera or a speed trap.
  14. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    gps is very accurate i believe, try it along with your original speedo and compare
  15. rustyscooter
    I don't know what they are, can you give me a link to one, or the make and name of one if you were going to buy one for the purpose of a speedo
  16. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    i'm on android and i've only tried Ulysse Speedometer, if you're wondering what make my phone holder is, i can't remember, but you can pick one up from your local bike store or ebay
    scubabiker and rustyscooter like this.
  17. Mark Emerson Trentham
    How would that set-up work with a touch screen?.
    rustyscooter and Subw00fer like this.
  18. kierran
    kierran Active Member
    That GPS Speedo is great much more accurate!!!! I run it along side a digital Speedo to check id set it up right and it was cock on just uses a lot of battery
  19. Subw00fer
    Subw00fer Snqʍ00ɟǝɹ
    70cc NRG
    The plastic that sits over the screen allows the phone to be used somehow
  20. Dwaine
    Dwaine Member
    piaggio zip
    i have used the ulysse app works fine also android speedometer works great to,,,if you have a android phone that can accommodate apps just go to your app store type in speedo and they will pop up then just download them,,but you will have to have a internet (gps) connected via your mobile network
    hope that helps
    rustyscooter and kierran like this.
