Hmm weird when i had that on i had my normal standard jet in 54 now am at 56 for the exhaust and its a nice coffe colour spark plug am going to try refit this again now that i got more knoledge last tine i tried was last year when i was 15 couldnt even ride the ped yet just used to start it up in the garden. If i was to downjet would i be lean may go to a 55 . Also do you have any help on y my airfilter hole has to be blocked up cleanes the carb
Hmm thays weird when i first got it. It had a washing up sponge for the air filter thays when it worked best still have that sponge may give that a try
oooo ok, yer the spunge would be like a VERY restrictive filter and would have a small(i think) jet. it would also be why it starts when it blocked. buy or fit if you have a good air filter and buy a jet pack
So am thinking for this problem i would need downjey because my moped probaboy running rich with the filter covered
no if it was restriced with the sponge fitting a filter that will flow better would need more fuel. like i said you need to get a jet pack.
my speedfight with stock carb, MHR Rep and free flow was on an 82 so i would think you would be around the same
I got a 70 laying around in my spares from when i had the my open sports air filter am going to try that and order a box of jets and rollers and see how it goes i wish there was a easier way to get to the jets instead of taking of the whole carb
how do i know if my speedfight is cat i got a sports exhaust on right now but i think its still running standard rollers
oh okay i ordered 6.2 rollers and a 64 jet i also got a 70 62 and 68 in my spares let you know how it goes with all this would i be able to powerwheelie
hi i got my jets i started from 60 to 70 all the 60s it bogged down and when i done full throttle it died the 70 it stayed running even on full throttle but still bogged so i have to get more jets but am thinking since it stayed running with the 70 its in the 70 range. i didnt know you have to upjet so much for a sports airbox not even a open sports one i just put my standard airbox back on with a 56 jet
what air box do you have on? link me plz. am open type filter would need arounf 20% more fuel, with 0% gains on a low spec engine. sports exhaust need around 2-5% more fuel, with 10% power gains on a low spec engine sports cylinder kit(70cc) need around 15% more fuel. with 50-75% power gains on a low spec engine open filter just make noise and drink fuel.
http://www.pedparts.co.uk/product/1458/peugeot-speedfight-tunr-racing-airbox-air-filter. Its not even a open air filter just has a bigger opening to the carb to allow abit more air and they say you dont have to upjet which is not true i was even told when speaking to pedparta you do need to upjet .
The inlet where the carb sucks air through in to the carb is pretty big compared to standard which ia quite a small hole but i didnt think you would need to upjet that much since its a airbox
Finally got it running with my standard air box and withoit the air bok hole being covered its running on a 82 jet my acceleration is perfect now and the air box has a few holes drilled in it dont know why i had to upjet so much
