I use the above scooter to commute to work but there is a bit of road which is 50mph and would like to get to that speed It's been derestricted exhaust/variator/cdi unit it has 9g rollers in standard jet and carb it does 50mph on speedo but 42mph on gps Would putting a bigger jet in say 80 help or would it bog down ? Any help would be great
thats about it paul as fast as your going to get the little 50cc motor to go. the only other option is a big bore kit so you have more power to pull a gear up kit, or to have the standard cylinder ported out and thats not cheap by any means and you power gain would be below that of a big bore kit but treble the cost of a big bore kit
