Will take photos tomorrow, I have ever panel of and cannot locate another CDI, the bike isn't a immobiliser one I have checked that already. Will upload them first thing in the morning
Hello guys, Partners has just got out hospitals so I can get the pictures today. Just a update: The bike has a wicked blue spark, I have tried to kick the bike over and every single kick I do smoke comes out of the exhaust, If I keep trying to kick it the bike will back fire, I haven't managed to get it started as of it What Iv Changed HT Lead Coil Piston and barrel Stator and pick up Thanks
hmmmm.... did you follow my advice about the choke curcuit? im out of ideas if its not that, possibly a blocked exhaust or crank seals.... but try with the carb/choke clean first, and maybe change the auto choke too
Crank seals or weak mixture is my guess. A weak mix will cause a backfire, a blocked exhaust just makes more noise.
Thanks for all your help lads... My friend had a speed fight engine, so swap my piston and barrel also the stator, swapped it all over gave it a kick and what do you know it started
I used the same piston and barrel and the same stator, so must have been the woodruff key or crank, or compression
