Sold the Runner.. UPDATE: new TZR
Discussion in 'Bike Chat' started by Dunney-LFC, Dec 1, 2007.
  1. alexsr70
    alexsr70 New Member
  2. Dunney-LFC
    Dunney-LFC New Member
    Ok thanks again..
    What do you think about using a BR10ES?
    Also, Had a 10-15 minute drive a while ago, drove ok for the first few mins but then hummed and died after a gear drop.. Thought I had run out of petrol..
    Then it wouldnt start..
    I put ON the choke and it started and drove home fine :confused:arc:
    What does that mean?
    Even in the garden when I got back, I was just revving it gently and it was still dying when I gave it throttle without the choke..
  3. haugh
    haugh New Member
    Bikes cold?
  4. wobbly_trials
    common problem, lack of fuel. clean the carb, check the compression. welcome to the unreliable world of geared 50s.
  5. Dunney-LFC
    Thanks again..
    I think its something to do with the petrol line, as the bike seems to run better on the reserve tap?? :wtf:
  6. wobbly_trials
    clean the vaccum tap out and drain the tank. unless its just low on fuel
  7. Dunney-LFC
    What gear oil should I use? And where is the drain plug?
    Is there a haynes available for the teezer? Have looked around and cant find one..
  8. wobbly_trials
    use silkolene "light gear oil" or 10w40 gear oil (can use 4 stroke bike engine oil)
    should take about 1/2 a litre
    i don't think haynes do a manual for these.
  9. zumaman
    zumaman New Member
    Hey W_T, do you recommend Full Synthetic? I use that in my Aerox.
  10. wobbly_trials
    no i reccomend EP90 for your aerox and it will only take 110ml, unless of coarse youre on about 2 stroke oil. bit offtopic but any fully synth is ok for a 2 stroke scoot.
  11. zumaman
    zumaman New Member
    Thanks, and sorry about the off topic crap. My bad.
  12. Dunney-LFC
    Thanks, thats brilliant.. Do you know where the drain plug is?
    I just changed the plug, I think it is running a little lean...
    Here is a pic of the old plug (sorry about the quality)
    What do you think?
  13. rossmofo
    rossmofo New Member
    gilera Ice ZX7R
    :D I'd be happy with the colour of that plug!
  14. wobbly_trials
    plug looks okish, cant really tell perfectly.
    the drain plug is under the engine i beleive, its about 15 or 17mm bolt head.
  15. Dunney-LFC
    Thanks again..
    I finally got round to cleaning out the carb today..
    Its actually only a del 12mm, running on an .82 main jet..
    I still believe it is running slightly lean, and I am going to fit an open filter (for handiness when working on carb), so.. Will I order a set of jets 100 and under, or 100 and over?
    Also, does the filter need to be 32mm?
    I am going to do the oil next..
    Does the standard reed block work as a restrictor? It looks restricted..
    Would I be right in thinking the standard front sprocket in 11t? Would you advise going for a 13t? I would like a bit more top end..
    Thanks again.. :w00t:
  16. wobbly_trials
    under 100, i'd say 84-86 as your plug isnt far out. can't tell you the size of the filter.
  17. Dunney-LFC
    Thanks ;)
    Any idea about the sprocket?
  18. wobbly_trials
    speaking from my experience, try 1 tooth and 2 teth bigger than you have on the front, find the closest one
    you should just about be able to red-line the bike on a slight downhill in top gear. get it close then alter with rear sprocket sizes.
  19. Dunney-LFC
    Brilliant, didnt know that at all..
    At the moment the bike redlines so much in sixth gear, it sounds like it needs another six gears :w00t:
  20. nibbles
    nibbles Active Member
    and the cagiva mito to diss that you have to diss a legendary ducati
    enough said
