skipper st 125 air temp sensor loction
Discussion in 'The Workshop' started by baileywhite, Jul 24, 2017.
  1. baileywhite
    baileywhite Member
    anyone know where its located
    its working but randomly flashes in the minus then back to normal?
    thanks in advance
  2. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    its built into the piaggo watch , that clockwatch unit has a retail cost of £198 i have the same problem on my skipper, mine reads Low all the time and when battery has a hissy fit it will read -17 degree the shoot upto low again, i also have the flashing snowflake icon 24/7 to lol. theres no way in hell im paying near on 200 quid for a darn time piece i could get a 190 bore kit for near that price.
  3. baileywhite
    baileywhite Member
    huum had a feeling it was dash
    been playing up since all the dam rain
  4. Tamiyacowboy
    Piaggio Skipper
    yeah notorius for water ingress, my watch clock is water damaged when ignition is off you cant even tell what the time is theres lcd bars missing and leaking and likes , piaggio skippers are known for having problems with water ingress on the main dash and the watchclock
  5. baileywhite
    baileywhite Member
    thanks for the replies
  6. baileywhite
    baileywhite Member
    tonight i took the 'watch' off the dash and opened it up as i had water and vapor behind it and the display went all fooked up
    i dried it out and managed to get it working again but i couldn't see a sensor inside it, there are not any holes in it either for the air temp to get inside
    i check out the clocks/dash i dont think its built into there either, checked behind the front panel but didnt see anything obvious
    any other ideas where the sensor might be
  7. Tamiyacowboy
    Piaggio Skipper
    only other place is it has been wired into the loom somewhere .
    i have not taken mine apart yet and aj sutton does not show anything in the way of sensor for the dash system
  8. baileywhite
    baileywhite Member
    Anyone else know where it could be
    Anyone with a skipper Haynes manual.
    Can't find much online for it
  9. Tamiyacowboy
    Piaggio Skipper
    skipper haynes does not show either, i have the haynes manual for skipper.
  10. baileywhite
    baileywhite Member
    ok so the temp sensor is sat in the plastics behind the yokes of the forks for future reference
  11. MARSH
    The skipper clock set has always been a problem, even when they were new they failed within weeks !
  12. baileywhite
    baileywhite Member
    update
    cleaned the connector (behind the front panel) for the loom and air temp sensor and reconnected it and now temp is fine now
    my piaggio clock wasn't leaking water until i took it all apart trying to find the location of the air temp sensor
    since i opened up the clock i have had water seeping in almost as soon as it rains and messes up the digital screen
    ive had it on and off afew times to work out where the water is getting in
    so ive rebuild the clock with white bathroom sealer
    i used my finger to put some sealer on top of the o ring inside and wiped off the excess so it didnt go all over when putting the top on
    i did the same with the buttons put sealer around them put the buttons in wiped of the excess
    cant really see the sealer after you wipe it down
    buttons still work as they did as its only the middle what moves
    tested today in super hard core rain and not a drop inside
    display seem alot better after being dried out over night
