Just brought some main bearings for my project and one side of the bearing has a plastic cage and the other side is open wich way round do they go the website i brought them off says open side facing the crank shaft maybe im being blonde but the shaft runs throught both side of the bearings do they meanfacing the crank webs ..... but if that is the case how do the bearings get lubed from the oil fuel gide holes what are drilled in the cases from the intake if the cage is blocking the bearings any help/advice please
skf c4 race bearings
if they have the plastic seals, the seals go facing outwards, when you pressed them in, you didnt press them in too far did you? the oil feeds should be clear. they get oil from the mix (you know it like swills around the crank). hope that helps
I not to sure but you normally fit bearings so the writing is facing towards the crank
Yes the open side goes towards the crank webs so when your fuel/oil mix goes round the crank area it lubs the bearings too
More threads in The Workshop
| CDI Unit | 20 Nov 2012 |
| 125 Zip Engine into a Pug Fly 100? | 19 Nov 2012 |
| Typhoon 125 Slow Acceleration and Semi bog | 19 Nov 2012 |
| Replacement back of ignition switch | 19 Nov 2012 |
| weird power | 18 Nov 2012 |
| variatorssss | 16 Nov 2012 |
| How much to up jet or change fueld/oil ratio!? | 16 Nov 2012 |
| PIAGGIO NRG WITH NOW POWER WHEN DRIVING AND PULLING AWAY | 16 Nov 2012 |
| Aerox Doesn't run HELP | 16 Nov 2012 |
| De-restricted CDI for Sachs SX1 works a treat | 15 Nov 2012 |
