Fitted the forks today bit harder than slot straight on because the speedfight forks are one sided the under body fearing i made around that so if standered (normal forks are fitted) like my showa forks that plastic bit has to come of or be cut a bit. im gunna try mine without it. also the front disc is on the out side meaning big disc is possible mallosi whoops away springs to mind
yeah iv ordered a NRG front wheel so all good an im gonna order the 280mm stage 6 disc asap, yh i thaught that might get in the way is there eneugh room behind the wheel to fit a radiator?
happy days! iv baught the 280mm stage 6 disc for the nrg front wheel and a nice hel brake hose just need a new calliper, hope it all fits without too much modding.. fingers crossed
next thing to do is book some time with the welder and get this engine mounted properly then i can start buying the engine parts and painting.. cant wait!
So my move with going with bars was bad mood dont like it. digital speedo is to much work cant be dealing with any more.wires so im after the trekker front wheel and spindal with speedo cable still atached to use the standered speedo intill after mot ill fit the one i wanted internet. forks look like this fitted . also got a close up so you can see that angle a bit better on the shock
that side casing is bliiing! yh i dont like the look of the downhill bars stick with the standard clock surround, you decided on a colour yet?
Panels gunna be last gota change my front speedo drive to a cable not electric. Get forks tightened up right. Hows the shock bracket coming on cant wait to buy one lol and malossi rear shock my bling bling back end
Also had a look about the rad for you so you can fit another rad kinda in about same place a runners rad is will look sweet and pleanty of air will blow past there so cooling is no proplem. or the are cooling tubes they look cool but always out of stock
Im gonna sort the bracket tomorrow been buzy all weekend, ill just post it to you for free it cost me nothing and once iv made one ill have the measurements so its easy to make another, you might need to moddify your body panels to fit round it
Cuting plastic is no proplem got my welder ready to put that bad boy on then stack it up with a nice malossi or pm tuning shock will finish it of
