Secma Funtech 50 to 125 Project
Discussion in 'Scooter Projects' started by DRJ-Performance, Feb 11, 2008.
  1. DRJ-Performance
    DRJ-Performance New Member
    Its classed as a moped, says so on the V5 too...
  2. rezzin
    rezzin Member
    What a joke. :confused:arc: Seriously.. :msn1:
  3. Nrg-Sam
    Nrg-Sam Active Member
    must be so fun that lol, how do the brakes work? do you have a front/back brake? could drive it flat out, keep the throttle on, slam on front brakes n spin it round lol :D
    couldnt you just get a sheet of perspex and make a windscreen
    if this was mine id look for a 12v heater that runs off a fag lighter, imagine that on a cold frosty day, mmm, cushty :cool:
  4. Jamie
    stop being so narrow minded man
    open your imagination too all the possibilities of a 172 engine :D :D
  5. lol
    lol New Member
    if i was u i would try and put 4 wheels on it and try and make it so u can make both wheels spin ;) drift lol
  6. Burns
    Burns Active Member
    Aprilia sr50
    get a runner engine and make it a drift motor!
  7. Sw1fT
    Sw1fT Active Member
    200SX S13
    or get 2 runner motors and mount them side by side.....
  8. Martin
    Martin New Member
    gotta say i love this idea xD
  9. rider4life
    rider4life New Member
    makesure you get tints when its on road.........dark tints
  10. DRJ-Performance
    I've never thought of that, could be a pain in the arse to get both engine running somewhere near the same though. I reckon I'm going to try a typh 125 engine in it 1st and see how it goes, going to be a right pain creating the wiring for 2 engines :wtf:
  11. Sw1fT
    Sw1fT Active Member
    200SX S13
    thats simple, all you need is the running electrics on one motor and leave the lights and everything for the other, they would need to be exactly the same or it would pull to one side, but would still be funny to drive
  12. DRJ-Performance
    Do you reckon if I used 2 standard Typhoon 125 engines they should both be matched enough to work with this, I can't see the throttle side of things being to much trouble as I could just run a splitter, rear brake cable could be fun though.
  13. Sw1fT
    Sw1fT Active Member
    200SX S13
    2 standard typh motors will still be different, there are always differences in case casting, barrel lining etc. minute differences will cause one motor to be slightly quicker and therefore the bike/car/thing willl pull to one side.
  14. Sw1fT
    Sw1fT Active Member
    200SX S13
    not forgetting the fact that the air intakes will be in different positions, thus atmospheric differences will cause one to run faster then the other, its tiny things but even if 1 motor is pulling 1mph faster through acceleration, thats 1mph worth of countersteering from you.
    what would be cool is if you set it up like a pod racer from star wars, 2 throttles, 2 motors, 1 for steering left, one for steering right, no need for a steering column then.
    can just ease off the right nad power on the left to turn right and vice versa, power both to go forward.
    doubtful to be MOT worthy but would be a fucking fun project.
  15. DRJ-Performance
    I think I'll just stick with a single engine, I remember seeing a slider or something done as a trike with 2 engines, might be worth trying to find it again and see how that was done. Failing that I think it would be best just to stick a standard typh in it to get it back on the road in the summer.
  16. MiNoR cOnFuSiOn
    the twin engine booster was a completly fabricated rear end.. basicly a twin cradle that took 2 engines. lots of work
  17. DRJ-Performance
    Had to fabricate a cradle for the NRG engine that was originally planned, now quite a few useful people so stuff like that shouldn't be a problem, its just the brakes and electrical side of things I'd struggle with.
  18. MiNoR cOnFuSiOn
    as said befor run electrics off one then just the cdi off the other.
    as for matching the engines? aslong as the throttles open at the same time (use 2 splitters instead of one for the throttle to carb's/pumps) the engines will pull in sync.. its an AUTO meaning the power needed is applied. think about it, its just like having half the weight. the engine's will work together. can tune one an leave the other stock, one just helps the other at whatever rpm there running at.
  19. DRJ-Performance
    Cheers Minor,
    I'm starting to understand what was meant with the electrics, you reckon with the 2 engines it could be roadworthy?
    What would I do about the breaks as it has a handbrake that works on just the rear brake and the footbrake works all 3 wheels, all of which are drums.
  20. DRJ-Performance
    Its just going to be a right pain to do, as the footbrake works all 3 wheels, or 4 with the twin engine, and the handbrake works on just the rear.
    I'd have to somehow alter the footbrake to operate both front brakes (Drums) & 2 Rears (Discs), other problem is that I wanted to stick with an aircooled lump as there isn't really any room for a radiator, tank and all the pipework from a liquid cooled.
