running ported 172 kit on standard cases
Discussion in 'Maxiscooter Tuning' started by DerbiGP123, Jul 15, 2018.
  1. DerbiGP123
    DerbiGP123 New Member
    As said above to curious if you can run a ported malossi 172 kit on standard cases? thanks
  2. MARSH
    Yes you can but you won't get the best results out of the barrel !
  3. DerbiGP123
    Thanks for the reply. Would it still.give more gains then a standard 172 barrel? I understand it won't work to it's full potential but if it gives out more power then a standard barrel?
  4. MARSH
    It sure will work better, matching the cases to the barrel is very easy compared to porting the barrel. Get yourself a dremel type tool and ally grinding bits and off you go !
