running issue / soo close :D >>
Discussion in 'Scooter Tuning' started by Hursty, Jan 6, 2008.
  1. Hursty
    Hursty New Member
    78 jet.. brand new polini set up rolers.. so they are kinda weird like plastic casings with a metal insert
    needle is on second clip up from the bottom
    4.2g rollers btw
    cheers
    ben.
    EDIT: i also think it could be a vacum problem.. for example.. it doesnt start when its COLD , unless i used cold start spray into the inlet.. so its basically handing over a slightly more flammable substance..
    and its fine at higher revs just when u let off the throttle and back on quickly.. but mehh i dunno tbh :) because the vacum would still work as the revs are still higher
  2. wobbly_trials
    drop the needle 1 notch (move the clip up one) see what happens
  3. Hursty
    Hursty New Member
    thats wot it was on before .. no good
    cheers
    ben.
  4. wobbly_trials
    actually i think it could be a clutch issue, my area used to do this
    would rev fine then if you shut off the clutch wouldn't let the motor spin. only below 20mph though.
  5. Hursty
    Hursty New Member
    mines below 30mph..
    but if i let the idle die down.. it rockets off the line.. with the front wheel off the ground grabs like a split second before it feels it should though
    wot setings did u use ?
    im running polini white spring.. polini vari and belt etc.. medium clutch springs and 4.2g rollers ??
    cheers
    ben.
  6. wobbly_trials
    stock, yellows, reds greens, made fuck all difference, eventually invested in a decent clutch.
  7. Hursty
    Hursty New Member
    thats the same dude.. im changing them and getting no difference..
    wot cheap.. but cheerfull sports clutch would u recomend ?
    cheers
    ben.
  8. wobbly_trials
  9. Hursty
    Hursty New Member
    cheers dude.. wot will the pull away be like ?.. it wont be too harsh will it ? and obv i dont have to replace the springs in that..
    malossi delta any good ? or a dr clutch ?
    cheers
    ben :D
