Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
Runner with 70cc MHR, Not as fast as expected, Help??
Discussion in Scooter Tuning started by scott, 23 Nov 2008
scott#1
Hi Guy's
Can you please point me in the right direction to set up my Runner.
Spec as follows.
Polini EVO 2 Crank
Polini EVO Speed Drive.
Malossi 70cc MHR Rep Kit.
9 Roller Polini Variator.
20.5mm runner Carb, K@N Filter, running 98 jet.
125 Inlet running Malossi reeds.
Polini Gear up kit.
At the moment while running in, i have fitted my Leo Vinci ZX pipe, once run in i'll use the Polini Evo Race Pipe.
At the moment it seems fine at low to medium revs, but when trying to increase revs to full throttlle, it seems as if it bogs down, produces a hell of a lot of intake noise but not exactly setting the world on fire. Almost as if holding back.
Any help very much appreciated, as with this setup i was hoping it would fly!!!!
Please help.
Cheers Scott.
gomz#2
biger carb deffinetly
Dec#3
mate fuck the zx thats why, these things need to rev at 14k+, bang the evo pipe on.
DYS VTR#4
take off the shitty zx and bang on a 25mm
eddiesmith#5
yeh that pipe will be restricting it like you would not believe, n ye bigger carb wont hurt, but may aswell wack your polini pipe on now
MiNoR cOnFuSiOn#6
sounds rich at full throttle but lean at part.. rolers are probably a little heavy.
move the clip on the needle down one and drop the jet size.. lightern the rollers to around 6g and work from there.
scott#7
OIl Pump set up
Hi Guy's
Thanks for the replies.
Can anybody help with Oil Pump set up, are their any marks to set to etc.
Cheers Scott.
capri dave#8
This has been covered a few times before on piaggio motor...searchy searchy ;)
james#9
scott said:
Hi Guy's
Spec as follows.
Polini EVO 2 Crank
Polini Gear up kit.
At the moment while running in, I have fitted my Leo Vinci ZX pipe, once run in I'll use the Polini Evo Race Pipe.
Any help very much appreciated, as with this setup I was hoping it would fly!!!!
Please help.
Cheers Scott.
Take it to a dyno and get it setup right.... simple!
I have said this a million and one times if anyone has all this cash to spend on tuning your scooter engine it is must to pay a few qwid to get it setup on a dyno so as you are getting the most out of your engines and all your roller and jetting issues will get sorted and be spot on.
Every scooter i have ever owned that had tuning parts on has ALWAYS left any sort of dyno up on power and runing better than before it went in even if i thought the scooter was runing great before it went in.
scott#10
Oil Pump Set-up.
Hi Guy's
Tried searching for info on the oil pump and cannot find anything, can anybody let me know how you set it up.
Cheers Scott.
MiNoR cOnFuSiOn#11
dyno setup is down to opperator.. and even then can still be way out. full power on a dyno isnt correct setup for on a road with a person.. just best max power. anyhting ive ever had on a dyno (bike wise anyway) ive ended up playing wiht as it wasent how i like it.. as for paying somone every time you change a part whats the point,
learn to get it close, when its built how you want it built dyno it.. then stop tunning..
capri dave#12
Re: Oil Pump Set-up.
scott said:
Hi Guy's
Cheers Scott.
lets hope your engine building skills are better than your searching skills :msn1:
http://www.scootershack.co.uk/viewtopic ... highlight=
scott#13
Oh Yeah!!!!!
oh yeah i can see where i am going wrong!! :wallbash:
Searched for
How to set up oil pump!! :sarc:
When obviously i should have searched for
increasing 2-stroke oil delivery. :msn1:
Cheers Scott.
Lazer X-pro & malossi airbox foam8 replies27 Nov 2008
Reed Block31 replies27 Nov 2008
engine cassings barrel fitting1 replies27 Nov 2008
honda today is now less gay.41 replies26 Nov 2008
something doesnt seem right ..........8 replies25 Nov 2008
HELP!!!!!4 replies25 Nov 2008
New style exhaust from Leo Vince31 replies25 Nov 2008
Problem8 replies24 Nov 2008
Spluttering when go to wheelie4 replies23 Nov 2008
Water Pump Problem5 replies22 Nov 2008
