runner strange sound
Discussion in 'The Workshop' started by Edgar, Dec 8, 2011.
  1. Edgar
    Edgar Active Member
    i went holiday so havent done anything , i got everything on the video the back 'axel' is moving up and down also in and out , crank is not moving anywhere and as you lot mentioned its hard to spin the fly wheel because of the compression , so does that mean my end bearing is gone??
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    I think that your bearings gone in the gear box or it's come out its shaft. that's not good lol. little movement is fine but that is bad....
  3. Edgar
    Edgar Active Member
    are you talking about the little bearing or some other ones inside the gearbox?? thanks for help
  4. Edgar
    Edgar Active Member
  5. Jonnymarrw00t
    Yeah. Or yours has fallen out ? You'll need it pressed back into the new bearing though.
  6. Edgar
    Edgar Active Member
    no nothing fell out yet , so do i take of the gearbox cover and go to some garage?
  7. Jonnymarrw00t
  8. Edgar
    Edgar Active Member
    ok, thanks a lot for your help mate
  9. Jonnymarrw00t
  10. Edgar
    Edgar Active Member
    Shot at 2012-01-03
    ok so i striped the gearbox and havent really found anything unusual , except that the axel can be take out easily from the bearing (as seen in second picture) , any ideas what should i do? do i still change the bearing as its in good condition spins etc
  11. Edgar
    Edgar Active Member
    there is the video might help , i stripped the gearbox got some grease on the bearing nothing happened
  12. gulliver
    gulliver Member
    did u check all the bearings in the gear box mate. and mainly the one in the gearbox cover that the rear shaft came out of. usually they dont usually just fall/come out easy, a little tug/taps normal to get them out and by the way it was moving up and down dint look right. being a rolling nut you do have a bit of play on the shaft in and out but not up an down. tidy skoot tho,wish i could keep myn clean but its used every day all day and ragged everywhere,engines all i care about and thats tuned enough lol !!!
  13. Edgar
    Edgar Active Member
    i will try changing that one, i ordered one but i accidently got the littleone as they dont have a flippin pictures on pm website , but ill try to order the big bearing and see if that helps, and thanks i cant ride this bike yet im not 17 lol but i will soon so this is why its so clean but ill try to use it only in dry days :), thanks 4 your reply
  14. tErr0
    Just out of interest have you checked the clutch bearing?
  15. Edgar
    Edgar Active Member
    nope is it the one on torque drive?
  16. tErr0
    Yep. Common one to go.
  17. Edgar
    Edgar Active Member
    will the torque drive from vx fit my sp ? as i could use my mates one to check?
  18. Edgar
    Edgar Active Member
    Finally !!!!! i stripped my torque driver and it expands so rough so i guess this is the problem , ill be going to some garage tomorrow and see what they can do, does any one know the rough price that they gona ask for???
    thanks for your help guys
  19. Edgar
    Edgar Active Member
    ok so no luck non of the garages want to repair that torque drive so im after a stock one or aftermarket one tell me what you got ?
  20. Edgar
    Edgar Active Member
    ok so i got another second hand pulley which moves smooth and guess what..... its the same shity sound i feel like smashing that bike in a wall now spending my last pocket money to buy parts and nothing... any one got any other ideas????​
